Tire question for Luke
Old Apr 18, 2009 | 03:25 PM
b1fong's Avatar
2000 E320 wagon
I have a set of W211 17" wheels for my 2000 W210. Problem is the 245 45 17 on the front rubs. If I mount 235 45 17 on the front the diff in circumference from front to rear is like 1.2 mph. Will this screw up any speed sensors?
Thanks,
Bill
Old Apr 21, 2009 | 12:48 PM
Ken Uyeda's Avatar
Collections Ban
Lorinser
Your 2000 W210 should be running 235/45R17 front and back. I would also be running custom lug bolts in your case as the W211 OEM wheels use 14x1.5 lug bolts and your W210 uses 12x1.5 lug bolts. You'll need 12x1.5 lug bolts with a 14x1.5 radial head for proper fit, plus the 235/45R17 tires.
