HELP!!!Does this wheel going to fit on W209
Old Apr 24, 2009 | 06:10 AM
azndaivd85's Avatar
CLK 320
Hi,
I have a set of Ace Strada Wheel for my Z4m, but my lease is up. SO i was wondering do those rims fits good on 2004 CLK 320 without any rubbing. If so which size of tire do you guys recommend!!
Ace Alloy Strada wheel set consist of the following:
Size 19"X8.5" Front 19"X9.5" Rear
Bolt Pattern 5-114.3 or 5-4.50
Off-Set 38mm all around
Center Bore 73.1
Thank in advance!!
Old Apr 25, 2009 | 10:04 PM
coin's Avatar
'06 CLK500
Originally Posted by azndaivd85
Hi,
Center Bore 73.1
Thank in advance!!
You need 5x112 bolt pattern
Old Apr 28, 2009 | 01:38 AM
azndaivd85's Avatar
CLK 320
If I use hub centric. would that cause any damage to car or unsafe driving?
Old May 1, 2009 | 12:27 PM
detail-king's Avatar
Former Vendor of MBWorld
Mercedes Benz CLS63 AMG
The hubs wouldnt make a difference as the bolt pattern is totally different. You may be ablew to purchase wheel adapters but the clk takes a et42 rear and you have a et38
Old May 7, 2009 | 07:46 PM
Ken Uyeda's Avatar
Collections Ban
Lorinser
These will not work at all. You should check with them to see if they offer the wheels in a 5x112 bolt pattern, offset in the low 30's, and centerbore 66.6mm. Also, when you mentioned that they are on your Z4m, are you referring to the BMW? Because the specs you listed won't fit the BMW either. You'll be better off selling those wheels to a Bimmer owner and purchasing a proper set for the CLK.
