Luke, need help with rim fitment please.
Old Jun 30, 2009 | 06:58 AM
jimmy5110's Avatar
08 e320 bluetech
Hey Luke, I received the TPMS sensors for my 08 E320 Bluetech last week and thanks for helping me with that order. I have Lorinser rim RS5 and fr is 8.5 and the rear is 9.5 with et all around is 38. the tires will be 245-35-19 fr and 275-30-19 rear.I talked to the guy at Discount tire and they said it should fit, then I talked to the guy at Lorinser and they said I will need hubcentric spacers 7mm.Now , I don't know what is right to do, can you help me to clarify this matter, so I can get some tires for my set up. thanks
Old Jun 30, 2009 | 01:40 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
A 19X8.5 et38 wheel will fit your car without issue but, the wheel design you have may need addityional room for brake clearance. Even with the exact same width and offset wheel often times have different amounts of brake clearance. Since that clearance issue is dependant on specific wheel design I would listen to the Lorinser person you spoke with since he works for the folks who made them.
