Need Alignment or Camber adjusted ?
Old Jun 30, 2009 | 10:03 PM
evanswan's Avatar
2010 E350 SP / Honda Crosstour / prior vehicles - C32 modded / C300 modded / Lincoln LS modded
Hi all. The photo is of my front drivers side tire. It is wearing on the outside at a rapid rate. Is this alignment issues or camber. the passenger side is fine and shows no unusual wear on the tire. I did just replace the rears with new tires and waiting to do the fronts. would this have caused the issue ?
Attached Thumbnails Need Alignment or Camber adjusted ?-_media-card_blackberry_pictures_img00019-20090630-1636.jpg
Old Jul 1, 2009 | 02:15 PM
GotDaBenz's Avatar
'03 C320 Sedan, '04 SAAB 9-3 Cabrio
Hi, I am not an "expert" but that definitely looks like a camber issue. First thing should be to have alignment checked and for any worn or broken front end parts.
Old Jul 5, 2009 | 08:19 PM
krisv420's Avatar
02 C320 Sedan
Mine is doing it also burned brand new tires in less then a year =/
Old Jul 6, 2009 | 08:53 AM
Rick SL55's Avatar
2005 SL55 AMG, 1986 Porsche 930S, 1996 Porsche 993tt
for a better camber & caster correction check K-Mac products.
Old Jul 6, 2009 | 11:16 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
looks like an alignment issue to me
Old Aug 9, 2009 | 11:02 AM
pickupjason's Avatar
C230 K
same here.. I am on stock staggered wheels without lowing the car.
but I had the aglinment checked before, the numbers of front end looks good and the only thing off spec is the passenger rear tire.
I am at 44K and the third set of tires now have around 6k. The driver's side tire now wears to wear bar already while the other side looks fine! the rear one looks new!
Is there a good alignment shop in So. Cal could get it fixed? Any recommendation?
