Need recomendations for tires...
Is there a better tire I need? My fronts wear fine. I've had the same fronts and have gone through 2 sets of rears. The outer tread on the rears are fine, and the centers wear. I have them at 40psi...same as the fronts. Is there a different tire I should be using?
As I stated, I have the same tires on my Mustang...that I drive the **** out of....but those rear tires last better than the same tires on my Benz. I dont get it? Please help. Thanks in advance.
1. Get a tire with a higher treadwear rating.
2. Proper inflation (looks like you have that covered) check for under/over.
3. The rears will rear out faster due to rear wheel drive, but do know approx. mileage you get out of the rears?
I would go for Michelin tire, such as the A/S Plus 500 TW high performance 45K warranty. My experience has been very good with tread-wear, have them on my CLS. There are others in that size as well.
I did this quick search on your car with 18's:
Discount Tire
Hope this helps.
I'm just wondering if I have a problem with my car though since I have had really good treadwear on my mustang with the same Kumho tires. They are Kumho Ecsta SPT 265/35's and they wear really well on my mustang that has way more hp than my Benz. I drive my mustang way harder than I do my Benz....so it doesnt make much sense to me that they wear faster on my Benz.
Another good source, Luke@tirerrack on here, he is a sponsor. Pretty well versed about these issues.
