Luke - Question - O.Z. Ultraleggera HLT
Old 09-03-2009, 08:07 AM
TR Moderator & Tire God
Luke@tirerack's Avatar
depends on the weather
Originally Posted by erichen
the specs for your wheels too? like to know what offsets y
front
20x8.5 ET32
rear
20x10 ET35
Old 09-03-2009, 08:46 AM
user z478747's Avatar
08 SL55
Originally Posted by Luke@tirerack
front
20x8.5 ET32
rear
20x10 ET35
Luke, are the wheels going to still be available due to the mismatch paint issue or is O.Z. going to do away with this wheel completely?
Old 09-03-2009, 09:01 AM
08 SL55
Hi Chuck, do you mind posting the specs for your wheels too? like to know what offsets you used and if you don't mind, can you post pics of how flush the wheels are with the flares of the wheel well? I like mine to sit flush and my worry is that the front's may not sit flush but may require spacers. Thanks! Can't wait to see your pics!
What Luke said on the offsets/sizes plus I did some calculations and determined that the wheels were going to sit too far inboard (for me anyway) so I added 10mm spacers and longer wheel bolts on all four corners. So far the rears look great and I'll post up some pics when the fronts are done.
Old 09-03-2009, 08:22 PM
08 SL55
Wheels installed minus the front spacers. Seems the hubs are just a tad different than the rears so the spacers I bought didn't fit. New ones to try being sent via overnight from Evosport as I type....
They turned out beautiful IMO.
Lots more pics here:
https://mbworld.org/forums/sl55-amg-...ml#post3699293
Old 09-04-2009, 09:20 AM
Looks Great
Old 09-04-2009, 10:58 AM
08 SL55
Looks Great
....so Luke, are these wheels still going to be available?
Thanks BTW. It does look pretty good if I don't say so myself.
Old 09-04-2009, 09:17 PM
  #32
08 SL55
Put the front spacers on tonight thanks to the guys at Evosport, when I called with my issue they jumped right on it and I had the right spacers at 8:30am this morning. While the difference is subtle with the 10mm spacer on each side I think it made a significant difference in the stance.
Old 09-04-2009, 11:43 PM
  #33
erichen's Avatar
04 SL 500, 09 R350, 09 E63, 2010 Prius
awsome! Thank you Chuck for sharing these awsome pics of your new toy! I think the spacers do make a difference. I have 8.5 up front too and I think it's inside the wheel well too much by around 1/2 inch. I am getting spacers in there too to make them nice, like yours! great job! Any other mods coming on this baby?
Old 09-06-2009, 12:48 PM
  #34
08 SL55
Thanks! The only other things we'll probably do to the car will be to lower it and an exhaust system.
Old 11-10-2009, 03:46 PM
  #35
Auraraptor's Avatar
Luke, what is the offset of the 19x11 rears? 42 and/or 45?
I assume neither will clear the '04 R230 SL600 (No TPMS) without the need for spacers?
The only reason is I want to run a 305/30-19 RE11 or 305/30-19 PS2. I assume for both I will need the 11in rear and the 10in will not do correct?
Old 11-11-2009, 09:47 AM
  #36
both
19X11 5-112 ET42
19X11 5-112 ET45
Old 03-03-2010, 10:02 AM
  #37
gp500e's Avatar
2006 E55
Luke,
Is the ULTRALEGGERA available in a 18" x 9" for a 2006 E55 rears.
Quick Reply: Luke - Question - O.Z. Ultraleggera HLT
