Coilovers with 19X9.5
Old Feb 21, 2003 | 01:12 PM
SungSmith's Avatar
Does anybody know if i can use H&R coilovers in a W203 sedan with 19X8.5 & 19X9.5 wheels? There seems to be only about 1/8 inch clearance from the inside if the rear tire and the shock...
Old Feb 21, 2003 | 02:23 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
they work with no problem as long as you are using the correct offset wheel and tthe correct tire size .... which sounds like you are
