Will OEM CLS AMG 18" wheels fit a 2003 E55 AMG? The tires are 255/40/18 front and 285/35/18 rear.
Former Vendor of MBWorld
the front tires may rub and the offsets on the CLS wheels are low offset. The front will be fine except for that tire size as you need a 245. The rear will be okay but may rub due to the offset.
Thanks for the info. It seems that I need an offset no lower than +30 in order to fit a 285 tire in the rear.
the offset in the rear should be between 38-42. et30 is too low!
You can run them on a e55 with a 245-35 f and a 275-30 r the offset are on the extreem
for the rear at 28 but i got my car slammed 2" in the rear and only rubbed with 4 people in dipps ..
but if you have your heart set on a 285 it all depends on the rim diameter. im running now a 285-25 on a 20" wheel with a 37 offset , same set up lowered 2" .
