Dumb question... please be kind.
Old Feb 22, 2003 | 10:06 AM
Cesar Santos's Avatar
2002C32AMG
Red face Dumb question... please be kind.
Instead of lowering the car, why not move up in wheel size without changing tire size? Example: from 225,45,17s to 225,45,18s?
The effect, at least visually,will be a fuller wheel well- just like having the car lowered. I'm assuming that the speedo calibrations and alignment issues would not be too complicated.
Or maybe they are? Also would the ride quality (of the bigger wheels) be at least the same as the original (stock) wheel/tire setup? Has anybody done this? After you're done laughing, could anyone tell me why not do this?
Thanks in advance.
Old Feb 22, 2003 | 10:38 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
altering tyhe overall diameter will effect other system like the speedo and ABS brakes not to mention the possiblity of the tires rubbing.... that's the short answer
Old Feb 22, 2003 | 10:40 AM
CRB's Avatar
CRB
As the wheel gets bigger the sidewall gets smaller and the perceived gap between the tire and wheel arch looks bigger. The "change" is purely an optical illusion. But most people buying larger wheels are going for a "look".( And not the Rubicon Trail look, either.) Go to the Tirerack.com site and play around with thier graphic that shows this phenomenon quite nicely.
Tire rack lowering graphic.
Hope this helps.
Old Feb 22, 2003 | 03:44 PM
SiLvaC32's Avatar
C32
you can never fill up ur gap by gettin bigger wheels w/o problems. just lower it! u get better handling anyway~
Old Feb 22, 2003 | 08:58 PM
Ted Baldwin's Avatar
300ce
..............lowering the car decreases the center of gravity and improves and makes the car more stable especially when cornering.
Ted
Old Mar 1, 2003 | 01:05 AM
ndabunka's Avatar
No longer car shopping...
Doesn't lowering also
Doesn't lowering also make a rough riding car ride even rougher? Remove what little spring suspension there is in these cars and you can also bottom out. I agree that a lowered car looks good but I don't know that I'm willing to set aside what little shock absorption that's already there.
Old Mar 1, 2003 | 01:14 AM
tpliquid's Avatar
too poor now
yes u can fill up gap, put in 22's with 225/45/22 shold fit it no problem
