Camber adjustment on E430 (W210)?
The correction bolts are about $20 each, and your car can take 4 of them. The bolts replace the front lower control arm bolts, which offset the arms to change the alignment. This is the part of the alignment that becomes expensive. Most dealers charge about 1.5 hr labor for the alignment, then for the correction bolts on top of that they may charge an additional half hr labor to install each bolt.
As far as the rear, there is no factory adjustment, and no factory correction bolts for the rear. There is a company that does make aftermarket arms which are adjustable, but they are really expensive and not necessary for a street car. These arms ar $600 for the set.
