S500 wheels on a CLK320
Old Mar 19, 2003 | 11:47 AM
jpmotdyn's Avatar
Will 03 S Class wheels fit a CLK 320?
Old Mar 19, 2003 | 02:02 PM
Harris's Avatar
Re: S500 wheels on a CLK320
No, wrong offset and bolts.
Old Mar 19, 2003 | 04:35 PM
jpmotdyn's Avatar
Re: Re: S500 wheels on a CLK320
What do you mean by bolts? The length ?
Old Mar 22, 2003 | 11:21 AM
ViKTORiOUS's Avatar
W209 - W163
cant you fix this with spacers? Cuz i was thinking of buying 2000 S-Class wheels for winter rims.
Old Mar 27, 2003 | 12:49 AM
E55AMG99's Avatar
1951 Caterpiller D6
The SL500 wheel fit my '00 CLK430 with only minor milling on the fronts.
Old Mar 27, 2003 | 11:24 AM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
Harris is right. S500 Bolts are 14mm and CLK uses 12mm. A 12mm round lugbolt does not 'seat' correctely in a 14mm seat on the wheels. In order to use the 14mm lugbolts you need to redrill the brake hubs.
S-Class offsets are high and putting them on CLK will push the wheel inward to far. You would need to use a spacer to keep the wheel from going in to far.
Old Mar 27, 2003 | 11:28 AM
E55 KEV's Avatar
Veteran: Air Force
Recommend buying a used set of OEM CLK Mercedes wheels like the ones you have or similar.
