Wheel came off! (2007 S550)
Upon inspection, it appears that four of the five hub bolts broke off inside of the hub.
My question for all of you is: What would cause that? The last place to touch my car was the tire shop when they replaced a tire (I'm still confirming whether it was the same tire).
My car dealer suggested someone OVER torqued the bolts. Possibility? If so, what are the torque specs for a wheel on the 2007 S550? Any other suggestions on how this might have happened? I don't believe I had chrome bolts, since I did have a decorative cover over the bolts.
Thanks for any help you can lend.
Another thing to look at would be the lug nuts you have installed. If you've got aftermarket lug nuts, they're often sand cast or mold cast aluminum that aren't as strong as the standard OE ones. Also, for the lug nuts, you need to make sure you've got the proper seat type, thread length, and thread size.
Tightening torque for your lug bolt should be 110 lb/ft or 150nm.
