Whats the proper tire presure for my 19" tires ?
Old Mar 19, 2003 | 07:06 PM
trustz's Avatar
2010 W204, 2014 W212, 2015 W222, 07 SAAB 9-3, 2016 AMG GTS
Hi all,
I got my 245/35/19 tire in the front and 275/30/19 in the rear, what is the proper tire presure for the tires ? thanks in advance !
Trustz
Old Mar 20, 2003 | 08:53 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
32 front / 33 rear + / - 5 psi
Old Mar 20, 2003 | 05:40 PM
henry47's Avatar
asdf
you might want to consider around 40 psi JUST IN CASE you were to hit any potholes. I agree with luke that those are the PROPER pressures, but it's better to be safe than sorry. BTW, I'm running 39 to 40 psi on 235/35/19
Old Mar 20, 2003 | 06:06 PM
trustz's Avatar
Luke: thanks a lot, you must be the same guy at NASIOC.com. I used to have a 2002 WRX and I bought a 18" Prodrive P1 and tires from you guys a year ago ! super deal and super service !
henry47: thanks for the advise, I thought the same thing too,because I put 35 psi in my 18" wheel on my WRX, Now with 19", the tire even more low profile , may be 38-39 psi should be safe !
trustz
Old Mar 20, 2003 | 06:27 PM
Turbo]['s Avatar
98 E430
I would probably go 35 front and 36/37 in the rear, depending how often you have passengers.
I put in about 39psi in the rear because I have a full sound system in the trunk.
Old Mar 21, 2003 | 08:39 AM
nickv's Avatar
Used to be a CLK430
I'm running 38psi all the way around.
