ABS brake pulse after changing to a/s tires?
Old May 22, 2010 | 08:11 PM
mystery905's Avatar
2012 E300 4Matic
I finally changed my winter tires to new all-seasons (Hercules MRIV 205-55-16) a few days ago at highly recommended Simply Tire in Toronto.
I get no vibration even at highway speeds indicating they are balanced properly. However, sometimes when I brake I feel what I think is ABS pulsing.
Can this be me not used to the increased stopping distances required with a less 'sticky' tire, and/or the need to break in a new tire?
http://www.tirerack.com/tires/tirete...e.jsp?techid=5
They put them at 32 psi and I increased them to 36 psi with no change.
Also, I've had the Check Engine light indicator for a while which I feel is unrelated
Old May 22, 2010 | 10:05 PM
i_am_amused's Avatar
2004 S55 (SOLD, miss it every day), 2009 GL550
I changed from Goodyear summer tires, that were much stickier than winter tires, to Continental all season tires and my ABS hasn't done anything out of the ordinary.
Are your tires the same size as before?
Are your brakes wearing?
good luck.
Old May 23, 2010 | 08:49 PM
mystery905's Avatar
2012 E300 4Matic
Yes, the tires are the same size. I've driven them some more and the problem seems to be gone
Old May 24, 2010 | 01:21 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
it could very easily be that those tires have less stopping ability ... the ABS system is seeing a lockup so it's activating as designed
