E320 Lorinser wagon "sway/lean"
here's my car that i'm going to get some 17 or 18" wheels on soon...still debating on comfort vs. performance.
http://www.gkautos.com/00e320wagon.htm
my question is what's causing my car to "sway" or "lean" when i'm changing lanes or going around a long bend? the shocks seem to be fine, and in panic situations the car actually performs quite well. it's just that the initial movement of the car in anything but a straight line seems to make the car "lean" or "sway"...wondering if anyone could explain this or suggest a solution. obviously getting 45 series tires will help the Lorinser suspension, but do i need sway bars or new shocks?
thx.
patrick
I used H/R Spring set with #1bump/notch front and rear With Sport Shocks (In The Front) With 18s On My W210Wagon
It Still has lean on corners..But its Much Better
I Will be Installing E55T AMG Sway bars soon..to see if it will help?
To Help You On The Lean Question...The Tall OE Tires..Soft Shocks/Springs..Are The Answer.
thx for your input. look fwd to your f/u when you add the E55 sway bars.
coincidentally, i was down in your neighborhood this past wknd dining at arches restaurant and cruised by huntington beach a bit when i took the wrong turn. it was on jamboree from irvine to PCH that i noticed the lean quite a bit...so i'm looking fwd to new wheel/tires. i do get a slight buzz from my sunroon interior shade, so i'm wondering what your set up is on the 18" wheel/tires for size as well as your input. thx.
easiest thing to do is the upgrade of sway bars...that's what they're designed to do, keep lean/sway/body movement of the car at a minimum. keep in mind tho, the larger u go...the less "independent" movement ur suspension will become, and will also result in a less compliant ride.
hey, the benz chassis is already ultra stiff, so the compromises aren't as bad as say, on a nissan
mark,
and Sport Front Shocks
Im Happy With the Ride ...Its Not To Firm...
I Think it will corner better with the E55 T Sway bars
Yeah I Know Its a Wagon..
