The great brake rotor controversy
sillydriver
A recent thread on this board included a heated discussion of whether or not AMG has installed the cross-drilled brake rotors on one side of every car backwards. The argument was that the spiral pattern of holes (and hence the spiral pattern of ribs inside the rotors) was oriented differently on each side of the car, so that the spiral ribs would act as a centrifugal blower on only one side, while the brakes on the other side overheat.
When I looked, this was indeed true of the rotors on my SL55: the spiral holes were oriented in opposite directions. And I saw it was also true of the cross-drilled brakes on my S500.
Clearly this is strange, because while the argument about centrifugal cooling is a good one, it’s also hard to believe that the engineers at AMG and Mercedes Benz are all sloppy or stupid. So I had a talk about this with my car guru, a good friend of mine who collects high-performance cars and is a connoisseur of all things mechanical.
His opinion was that there was no blower effect on either side and the different orientations of the rotors were equally good. He reminded me that centrifugal blowers have their air intakes at the center, while the centers of brake rotors are blocked by the hubs on which they are mounted.
But what about the holes drilled into the rotors? He replied that there isn’t enough air flow through those for a blower effect and added it is a common misconception that the holes in cross-drilled rotors are there to create air flow to cool the brakes. In fact, they are there to prevent brake fade in a different way. After repeated hard braking, the pads and rotors get so hot that resin that binds together the material in the brake pads begins to boil away. This creates a cushion of hot gas between pad and rotor - essentially an air bearing - which reduces friction and causes brake fade. The cross drilled holes are there to vent that gas from under the pads, maintaining friction. Air flow through the holes is secondary.
But what about the spiral ribs, I asked. He replied that they are not there to pump air, but to separate the halves of the rotor while stiffening the whole assembly. The rotor would be weaker if the two halves were separated by radial ribs, since lines of flexion going through the center of the disk would not cross a rib. When you have spiral ribs, any line across the disk does cross a rib, hence that is a stronger configuration. The ribs aren’t meant to be blower vanes at all.
I can’t guarantee that his views are true, but it does explain the mystery.
Report this post to a moderator | IP: Logged
04-17-2003 11:52 AM
jco-amg
Thanks for the intelligent explanation...it is quite believable...I have had a hard time believing that AMG would have made such a blunder and felt that there was more to the story here...as I mentioned before...if you look at the AMG F1 Safety car brakes the pattern is different...looks like even more holes.
__________________
2000 CLK 430 Silver...passed along
2001 CLK 55 AMG/RS Black...passed along
2002 ML 500 Sport Capri Blue
2003 SL 55 AMG on order!
04-17-2003 02:54 PM
E55 KEV
Good Points. I always heard the holes are there to emit gases and dissipate the heat. The holes allow the internal heat to come out through the holes or escape instead of building up inside the rotor.
So maybe it does have a 'cooling' air effect but the holes do not bring or pull cool air inward but allow hot air to come out.
Instead of blowing air in the holes only allows hot air to escape. Hence the holes do not have to be in any particular pattern because they are not vanes just holes.
__________________
My Website - www.E55AMG.com
2002 Mercedes-Benz E55 AMG
2001 Ford Explorer Sport Trac
1998 Mercedes-Benz E430 (traded)
04-17-2003 04:19 PM
jswedberg
I'm pretty sure my '97 993 had the holes spiralling the "wrong way", as well.
I have always thought the holes were purely for wet weather and pad-dust (and resin gas) release, not necessarily for cooling.
__________________
Silver '02 AMG C32 - K2a, COMAND, Xenon, Rain Sensor, CD Changer
Bordeaux '00 ML320 - M1, M2, M5, Bose, Heated Seats
Red '86 Mazda B2000
Gold '01 Toyota Corolla
Red/White/Blue '86 Suzuki GSX-1100R
04-17-2003 05:11 PM
matoy
Sillydriver
I am sorry but your friend (car guru) doesn't know that MB rotors
ARE NOT BLOCKED by hubs at the center, there are even air
intake scoops to increase air flow to the center of rotors!
THIS IS WHY MB AND AMG ENGINEERS ARE IN BIG TROUBLES
TRYING TO EXPLAIN THEIR BRAKE DESIGN.
regards, KM
matoy has attached this image:
04-17-2003 05:34 PM
matoy
[QUOTE]Originally posted by jswedberg
[B]I'm pretty sure my '97 993 had the holes spiralling the "wrong way", as well.
Porsche 993, 550 Maranello and some other sports and racing cars has non-directional rotors as showed on pic. It really doesn't matter if the holes are spiralling the wrong way.
04-17-2003 06:38 PM
04-17-2003 11:52 AM
jco-amg
__________________
04-17-2003 02:54 PM
E55 KEV
__________________
04-17-2003 04:19 PM
jswedberg
__________________
Red '86 Mazda B2000
04-17-2003 05:11 PM
matoy
Sillydriver
regards, KM
04-17-2003 05:34 PM
matoy
04-17-2003 06:38 PM
1996 C36 AMG, 1995 Volvo 850 Turbowagon
yes, the outgassing of gas between pad and rotor is the main reason for cross-drilling. i'm sure the internal ventilation is in the proper direction, swept backward instead of forward. but that still doesn't explain why mb/amg got lazy and did the cross-drilled holes backward ... no one else (at least in my recollection) does that.. even when my brembos look swept forward, the cross-drilled holes are actually still swept backward ...the holes just happen to line up so that they look like they're almost sticking straight out from the center...
caliper is in front btw, bumper side..
![](http://www.stickypix.com/data/6034/10913_brembo_lotus__3_-med.jpg)
![](http://www.stickypix.com/data/6034/10913_brembo_lotus__1_-med.jpg)
steve s
Look at this image of my SL55 right side rotor, do you think ventilation is proper if cooling vanes are swept forward.
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
The backing piece behind the rotor DOES HAVE AIR SCOOPS to channel air into the center of the rotor. There, the radially shaped vanes help move the air out of the rotor, including any outgassed pad material.
Previous Mercedes with radial vanes (anything based on Brembo calipers without cross-drilled rotors, or the W202/W208/W210 AMG brakes) have a DIRECTIONAL PATTERN with a proper orientation for each side of the car. It is silly to think that different applications would be manufactured if no benefit exists.
With the introduction of cross drilling on recent Mercedes, and the move to lower-cost rotor sources, there is now only a LEFT HAND application for all cars, and this application is used incorrectly on the right side of the car.
I visited AMG yesterday in Affalterbach but they were all too busy with vehicle deliveries (of cars assembled in Sindelfingen, weird) to answer my question regarding the brake rotors.
So, I believe it is due to a cost cutting measure, just as the addition of the crossdrilling is primarily a cosmetic feature. I don't believe AMG is concerned with all-out performance anymore.
For many of the Mercedes brake applications, one can find a rotor that will fit and have a choice of:
1) Proper directional pattern (left and right application), better cooling, not cross drilled
2) Cross drilled primarily for cosmetics but to aid in outgassing and reducing pad squeal, reduce rotor weight, increase rotor surface area to aid in cooling, but have inferior cooling on right rotor due to inefficient air movement through rotor
p.s. one can find technical articles concerning the application of directional vanes on brake rotors
-s-
-s-
i think scorchie may have a point. i really don't think the ventilations should've been swept forward, even if the drilled holes are forward. mine sure doesn't do that...both sides are swept backward. but this other thread indicates that there is only one rotor...c32 brakes/rotors part #
