Need help ASAP!!!
Need help ASAP!!!
Found a great deal on a sweet set of wheels and would like to know if they will fit my benz.
20x8.5 Fronts 5x120 offset +22
20x10.5 Rears 5x120 offset +27
I would be willing to even get tires stretched.
Okay I dont get the joke? I did searches and didnt come up with whether or not spacers could be used with this bolt pattern, or whether or not these offsets would work. Or whether or not they would work with rolling the fenders or with just stretching the tires. I checked the stickys and also found nothing. So please, point me in the direction of which post I need to refer to since obviously your in the know.
Former Vendor of MBWorld
1 Post
Mercedes Benz CLS63 AMG
The wheels you are looking at are 5/120 bolt pattern which was most likely off a BMW. You need a 5/112 bolt pattern so these would not work at all. Also, the offset is too low for the W220. Spacers would not work even if they were the correct bolt pattern as they would only push the wheels out even more. So unfortunately, these wheels will not work on your vehicle.....
