Will 2004 CLK wheel fit 2011 C350 ?
Old Oct 27, 2010 | 12:42 PM
R_Mak's Avatar
BMW E70 4.8i, E93 335i
I have a set of OE 17" winter set from my 04 CLK500
Wheel part#6-6-47-1702 MB 5 Spoke ET36
5X112 12X1.50b 17mm CB 66.6 17 X 7.50
and just wondering if that will fit a 2011 C350 4 matic. Thanks.
Ricky
Old Oct 28, 2010 | 12:38 PM
threeMBs's Avatar
Only MBs - the best or nothing
Ricky
Wheels will fit. However, if bolt holes are drilled to accept only 12mm bolts, then you won't be able to mount them as 14mm bolts that your car requires will not go thru smaller holes. Now if 14mm bolts do go thru, then you'll need to get 14mm bolts same length as your current 12mm bolts - if I recall correctly (and it was a while since I had CLK) MB used much longer bolts on CLK than on E, but I had W208 not W209. Usable length for OEM bolts on E (W211 and W212) is 28mm.
Old Oct 28, 2010 | 12:54 PM
R_Mak's Avatar
Thanks. threeMB.
