Questions on CLS550 Offsets???
Old Mar 21, 2011 | 02:22 AM
JS-CLS550's Avatar
CLS550
I want to know what is the most aggressive offsets for CLS 550 with out tires rubbing the fender? I am thinking of putting 245-35-20's in the front and 275-30-20's in the rear. Most likely, call will eventually be lowered.
Also, what suspension kits or coil-overs are available for CLS550?
Thanks in advance!!!
Old Mar 21, 2011 | 08:50 AM
threeMBs's Avatar
Only MBs - the best or nothing
Same as current SL (R230) - from 15mm to 20mm front and/or rear. With those offsets and tire sizes, use front wheels width - 8.5-9, rear wheels width - 9.5-10.
Old Mar 22, 2011 | 03:29 AM
JS-CLS550's Avatar
CLS550
So what your saying is 8.5 with 15mm offset or 9 with 20mm offset for the front and 9.5 with 15mm offset or 10 with 20mm offset for the rear, right?
Also I am planning on lowering the car. What's is the best and most cost effective way?
Old Mar 22, 2011 | 03:30 AM
JS-CLS550's Avatar
CLS550
Anyone else have any inputs?
