Brake Pad change for W203 2001
Old May 15, 2003 | 10:35 AM
paul-the-limey's Avatar
2001 C240 Elegance Auto Lthr
Hi,
I am in the UK and am in need of replacement brake pads on my 2001 W203 C Class. The car (as you all know) has ABS/BAS/ESP and wear sensors. I got a quote from MB for the work and it was over 2x as expensive as on of the UK's major fitting companies (Mr Clutch & Brake). My question is whether the fitting of the pads is a specialist job best left to MB bue to all the sensors etc or is it a job I could entrust to the cheaper (better value for money!!) outfit??
Are there any "watch-out's" I should hilight to them to make sure they do a good job?
Cheers,
Paul
Old May 15, 2003 | 01:32 PM
Mach430's Avatar
Changing pads should be simple at any shop. Typically, Mercedes dealers are more expensive than independent shops.
