Need Help Mercedes Benz 2010 C300 (Pulling to the right )
Old Jun 16, 2011 | 09:17 PM
raouf49's Avatar
Mercedes benz C300
Unhappy Need Help Mercedes Benz 2010 C300 (Pulling to the right )
Hello i currently have a Mercedes C300 2010 which is pulling to the right on any type of road, i have already did a 4 wheel alignment at my local Chrysler Jeep Dodge and it failed the alignment so i took it to my authorized Mercedes dealer for another alignment , which still pulls to the right and came with the same previous problem . So i really need a resolution to my problem because its obviously not an alignment or a tire issue because the tires are in great condition. Thank you very much for your time reading my post
Old Jun 18, 2011 | 04:38 PM
Mort's Avatar
Radial pull? Try rotating your tires left to right and see if that helps. Worked on my 2010 C63 after H&R Springs installed. It was puling to the right before and after alignment. The tech rotated the front tires left to right (not front to rear) and it came out perfect.
GL
PS: Make sure the tires are not directional or you will need to dismount/remount the tires. Also you can consider a road force balance check. If all tires are the same size then it may be possible to do an X type rotation that my cure your problem.
