W210 rim/tires fit W203?
Old May 26, 2003 | 10:13 AM
gmabm's Avatar
I thinking of swapping my E-Class W210 Carlsson 1/5 8.5Jx18 ET+28 with 235/40R18 tires into my C-Class W203.
I know the tires are slightly oversized as C-Class should be using 225/40R18 instead, but does it fit afterall?
Any rubbing of fenders expected or unacceptable inaccurate reading of speedo anticipated?
Thanks in advance.
Old May 27, 2003 | 09:47 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
8.5" wheel + 28mm offset + 235 tire size = severe tire rub
use a 35mm offset and a 225 tire size to prevent the rubbing
Old May 27, 2003 | 11:32 AM
gmabm's Avatar
Thanks.
Old May 27, 2003 | 05:00 PM
rob_fed's Avatar
W204 C300 2010
Do you have any pictures of your W210 with these wheels? Do the tires rub with this combo? Even if you do not have photos, could you please respond about how this wheel/tire combo fits a w210?
Thanks,
Rob Lee
