Funny noises after lowering
E320
I lowered my C320 with an H&R cup kit + 18" wheels. However I just noticed that on uneven roads (minor ones not major) I hear some noises in the front. Sounds strange, like a tire bumping the road hard or something. Makes me thing that something is loose. Other times when turning I also hear a little squeak in the back suspension. This is killing me.
Is this normal? Or should I take it back and have them double check everything?
E320
Went back to TWS and had them take a look. It was a combination of things:
1) Eibach sway bar polyeurothane bushings squeaking (needed lubrication)
2) The end of the Eibach sway in the front was scratching against the control arm of the suspension due to the H&R lowering (they had to sand off part of the end. alternative would be to get a shorter control arm)
3) Some nuts on were lose on the Eibachs so they had to tighten it.
No more noises.
No more noises.
2002 C230 : 2007 C230
oggle,
I can understand #1 & #3, that stuff happens, but #2 doesn't sound right. My car had Eibach sways & was lowered with both Carlsson coilovers & H&R cupkit and the sways never contacted the control arm.
