Will W204 / C350 wheels fit on my W209 / CLK320
Here are the details.
The W209 / CLK320 wheels are:
Front wheels: 16x7" ET37
Tires: 205/55R16
Rear Wheels: 16x8" ET32
Tires: 225/50R16
The W204 / C350 wheels are:
Front wheels: 18x8" ET50
Tires: 225/40R18
Rear Wheels: 18x8.5" ET54
Tires: 255/35R18
How can I make this work?
However, they can be "made" to fit, if you so desire.
For them to work, the following is needed:
1. You will need to run 15-20mm H&R spacers both front and rear, contrary to what anyone tells you, its obsolutely safe to do so;
2. You will need to find bolts to fit W204 wheels' holes (14mm) but having thread of 12mm for W209 - 14mm head bolts with 12x1.5 tread - these are not easy to obtain.
Tires from W204 will fit W209 just fine.
I would look elsewhere - there are a lot of choices to find wheels that will fit right.
