Will the 5x112 size 18x7.5 et38 fit my 2002 c230 coupe?
Old Sep 15, 2011 | 01:32 PM
Babybenzc230's Avatar
2002 C230 Coupe
I am planning to replace my OEM 10 spokes wheels to the Enkei Performance Series OR52 wheels. It has the 18 inch wheels and 38mm offset. I am wondering if it will fit into my car. Thanks for the helps!
Old Sep 16, 2011 | 01:49 PM
2002 C230 Coupe
Any help?
Old Sep 16, 2011 | 09:17 PM
GotDaBenz's Avatar
'03 C320 Sedan, '04 SAAB 9-3 Cabrio
Here's some help. Check with Tirerack, Discount Tire, or 1010 tires. All will show you what size wheels will fit correctly on your model.
Old Sep 17, 2011 | 02:47 PM
2002 C230 Coupe
Thanks for your reply. I have checked on those websites and I know the fact that everything will fit except I am not sure about the offset. Seems like most of the sites have it between 32~35+mm offset on the 18x8 wheels. This is 18x7.5 and 38mm offset. I am just not sure if this will have any negative impact on the fitment. Thanks.
Old Sep 18, 2011 | 10:48 AM
GotDaBenz's Avatar
Well, since you have narrower wheels and a little more offset it would appear they fit. The 1/4" each side is greater than the 3mm offset diff. Call Luke at Tirerack and he will tell for you for sure either way.
Old Sep 18, 2011 | 08:32 PM
2002 C230 Coupe
Thanks for your input. I really appreciate it.
