Offset got me crazy! Need help...
I'm looking for a new set of wheels for my W203. Maybe AMG or Brabus. I have read and learnt from several places (including this board) about the offset, and finally I got confused.
As said on TireRack (http://www.tirerack.com/wheels/tech/offset.htm), "If the offset of the wheel is not correct for the car, the handling can be adversely affected."
I don't know what offset my car has (if anyone know, please tell). Let's say (for example) ET 30.
The AMG dual spoked wheels (Styling IV) that can fit my car (according to AMG web site at http://www.mercedes-benz.com/amg/e/f...ichtmetall.htm) are...
AMG dual spoked wheel (Styling IV)
7,5 x 17 ET 37 tyre size 225/45
8,5 x 17 ET 34 tyre size 245/40 (only RA)
7,5 x 18 ET 37 tyre size 225/40
8,5 x 18 ET 30 tyre size 255/35 (only RA)
AMG dual multi-pieced spoked wheel (Styling IV)
8,5 x 18 ET 30 tyre size 225/40 (only FA)
You see? These wheels have several offset site, but according to Trirerack.com, the offset of the wheels need to be exactly the same as the original wheels otherwise the handling can be adversely affected. So, if the offset of my original wheels is 30, I will need only ET 30 wheels to replace, right?
Am I missing something here? Maybe I misunderstood something. Please help. I already spent almost a week finding info on the Internet. Thank you.
All of us in here will give you a hand as to which one will fit and which one wont. There are many many wheels out there which can be fitted on your car. Just pick a few first....and we'll go from there. Good luck!! :p
Here is an offset calculator:
http://toy4two.home.mindspring.com/offset.html
You can input your original offset and wheel width, then the program will determine how much difference from the original to new will be. As you input the various widths and offsets for the AMG wheels specified, you will see the inside and outside clearances will vary a few mm. Hence, fitting Luke's explanation.
So, what I have learnt from you are
1) Offset may not need to be EXACTLY the same as the original wheel from showroom.
2) Offset can be altered a few millimeters. (how far can I go, anyway?)
