Pressure loss sensor, runflat tires questions
2011 C200 CDI
Did a bit of reading up on older threads alraedy but still a wee bit confused. We have these questions for our 2011 C200. Some pictures attached:
- In the services menu there is the run flat indicator
- there aren't devices attached to the wheel valves - I'm guessing the sensors must be the indirect/inertia detection type on this vehicle?
- I can't quite tell whether the factory fitted tires are runflats (Michelin Primacy HP) - they don't have ZP or similar letters. Do all C's get runflats by defaults (NZ)? Just curious really
TIA!
TIA!
TR Moderator & Tire God
depends on the weather
where are you located?
All of the 2011 W204 C-class cars which comes to North America have a direct tire pressure monitoring system which uses a sensor attached to the end of valve stem inside of the tire. They also do not come with runflat tires.
All Michelin runflat tires are identified with a "ZP" marking on the sidewall
