H&R Springs for W203 - Need advices for camber adjustment
Old Jul 3, 2003 | 09:56 AM
charnchon's Avatar
W203
Hi,
I plan to get H&R springs for my W203 sedan.
Does camber needs to be adjusted? I was acknowledged that the W203's camber couldn't be adjusted.
What do they do when they set alignment after putting the new springs in?
Has anyone own W203 with H&R springs? Have you experienced any problem?
Old Jul 4, 2003 | 01:34 PM
nukblazi's Avatar
They adjust caster and toe
I have a slight pull to the right. I didn't notice it when I first installed my springs, so I don't know if it is just from the springs, or from the autocross I did on the 28th, or the bigger then a speedbump thing I hit on the way home... ???
I would have it checked, it isn't that expensive, and it couldn't hurt.
