F*cked up my rear brakes
Old Jul 20, 2003 | 05:36 PM
Bklyn1971's Avatar
1999 ML430
I got new rims about a month ago and everything was great. Since I live in NYC I went out today and got locks for them. The locks were alittle longer then the other bolts but i thought that shouldn't be a problem. After putting them on and backing out of the driveway I heard a "clunk" from the back drivers side wheel. Not knowing what it was I backed out the rest of the way and parked it in front of the house. I took out all the locks and reinstalled the old lugs but now I'm hearing a squealing and a clicking from the rear drivers side wheel. I'm taking it in tomorrow. I'm pretty sure it was the lug bolts. Now for the big question..... What did I f*ck up? I read somewhere about an e-brake, could I have damagethis?
Old Jul 21, 2003 | 01:09 AM
Some Pete Guy's Avatar
'82 turbo yugo
Re: F*cked up my rear brakes
Sounds like the dreaded transverse muffler bearing.
Big, big $$ to fix that.
Old Jul 21, 2003 | 02:46 AM
///AMG124's Avatar
1994 MB E420 RENNtech
Emergency Brake
You most likely messed up your emergency brake. Try putting on the emergency brake and see if the car will move forward. If so, than that is what has happened. I too did this once, and removed the studs immidiately. I was lucky, no dammage, but your story sounds different.
Old Jul 21, 2003 | 03:57 AM
tpliquid's Avatar
too poor now
800 dolla to fix it!!!
Old Jul 21, 2003 | 02:05 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
the longer lug bolt extended through the hub and mostl ikley damaged the parking brake asy.
