I am selling my stock AMG wheels off of my CLK 430 W208, 17x7.5 and 17x8.5; and this guy with a S class is asking me whether they will work on his S class or not... Anyone has any experience fitting CLK wheels on a S class?
Thanks!
Thanks!
I'd guess that since S wheels don't fit CLK cars, the answer would be no.
Quote:
Thanks!
from my understanding, S class uses 14mm bolts, and CLk uses 12mm bolts, in that respect, that means the holes will be relative to those bolt sizes.Originally posted by daimaru
Thanks!
With custom made bolts & spacers, you'll be able to fit S class wheels on a CLK.
But, since the S class requires larger bolts, I don't think you can fit larger bolts in a smaller hole...
Thats my thought at least... maybe the hole has enough slack to make it fit...
scorchie
close
Quote:
Spacers won't help, the offset on the CLK rims is already 9-14mm too low, and spacers just move it farther away.Originally posted by mmgrad
No, it doesn't... the 14mm bolt will not fit through the hole without drilling it.Thats my thought at least... maybe the hole has enough slack to make it fit...
-s-
Thanks!
Thanks!
no, the answer is simply no.
TR Moderator & Tire God
since nobody mentioned it, I tought I would point out that the load capacity of the wheel is also an issue if trying to install a CLK wheel on an S-Class ...
NO, THEY DO NOT FIT !!!!!!!!
good point... i guess most people don't think about the wheel's load capcity much...Originally posted by Luke@tirerack
