What would stick out further?
Old Nov 9, 2013 | 11:37 PM
TwinTurboTim's Avatar
2006 CL65
A wheel that is ET45 or ET60? I have 2 MB wheels on my car and the ET60 wheel sticks in more and the ET45 sticks out further. I am trying to wrap my head around this but it doesn't make sense. If the wheel is offset +45 why would it stick out more?
Is ET the same as offset? Does the numbers mean the same?
Old Nov 11, 2013 | 12:52 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types (measured in millimeters).*
Zero Offset
The hub mounting surface is even with the centerline of the wheel.
Positive
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly. We have test fitted thousands of different vehicles for proper fitment. Our extensive database allows our sales staff to offer you the perfect fit for your vehicle.
*Backspacing, similar to offset, is the distance from the hub mounting surface to the inside lip of the wheel (measured in inches).
