Can I fix my 1994 M-B E-320 Wagon's "Upper Control Arm"?
Old Aug 4, 2014 | 04:39 PM
carl.erlendson's Avatar
1994 Mercedes-Benz E320
Question Can I fix my 1994 M-B E-320 Wagon's "Upper Control Arm"?
In a collision with an on-coming car from the left-front, my L/F tire (wheel) was directly hit-- moving it almost to the wheel well. When any bumps or dips in the road are encountered, the sharp outer edge of the wheel well scrapes the tires outside tread/ sidewall. I've been told that I need a new "Upper Control Arm". Why can't this been re-straightened? Or can I get a used one from a wrecking yard? Amazingly, the alignment was not affected! I've been driving it like this for a year, but it's time to fix it. What might this cost? Does anyone have any advice? Sincerely, CARL ------
Old Aug 4, 2014 | 05:06 PM
AutohausAZ-Mike's Avatar
Former Vendor of MBWorld
Carl,
That control arm needs to be replaced for safety issue alone. The control arm probably has metal fatigue issues that could cause it to physically come apart. If that happens, you will have a bigger problem.
