Does anyone know the wheel specs
Old Jan 6, 2004 | 12:06 AM
GamblerZ's Avatar
Mercedes Benz ML500
Does anyone know the wheel specifications (diameter, width, offset) for the 2002 ML500?
Old Jan 6, 2004 | 09:29 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
AMG wheels
18X9 5-112 ET52
non-AMG wheels
17X8.5 5-112 ET52
and step lightly GamblerZ .... over here I am GOD and can banish you to purgatory for flamable behavior ....
just kidding .... welcome to the forum
Old Jan 6, 2004 | 10:03 AM
GamblerZ's Avatar
Mercedes Benz ML500
Originally posted by Luke@tirerack
AMG wheels
18X9 5-112 ET52
non-AMG wheels
17X8.5 5-112 ET52
Do the fender wells require any modification, or does camber require adjust to fit the larger AMG wheel size?
So GOD <snicker> you wouldn't be referring to behavior you've seen on other forums, would you?
Meanwhile, the EBC pads did *not* remedy the brake squeal. In fact, it is now non-stop. I will say, however, that pedal feel and braking were vastly improved over OEM. After scouring through this forum though, it would seem that brake squeal is an inherent problem with the M-Class MB.
Old Jan 6, 2004 | 12:34 PM
AMG's will bolt straight on with no need to change anything else other than the tires ....
we are alot more civilized over here
what is the diagnosis of the brake noise ... because all brake sqeeling is really pad vibration ... how are they going to fix that ???
Old Jan 6, 2004 | 03:09 PM
GamblerZ's Avatar
Mercedes Benz ML500
Personally, I think an oganic or ceramic pad might offer better results. If I am not mistaken, the EBC pad is semi-metallic? Wouldn't this exacerbate the problem?
Prior to my account here being mysteriously deleted someone had suggested to me in PM that he fabbed a piece of metal as a pad shim that eliminated this noise completely. But, as I mentioned, my earlier account was deleted along with the PM suggestion
How is MB going to fix it? MB says that all their cars do that. They actually had the nerve to tell me it was the way I drive my car! Keep in mind that the car is almost 2 years old and only has 12k miles on it. The car has *definitely* been pampered. What I find so mysterious is that none of my Nissans do this. Needless to say, my "Experience of Ownership" (as it so boldly stated on my MB welcome pack) has not been the greatest.
Meanwhile, I will install *the* filter for this more civilized forum so that others too may enjoy the experience. I only wish MB would OWN up to the problem.
