is it real or is it memorex ???? or AMG
#51
![](https://mbworld.org/forums/images/ranks/veteran_air_force.png)
Originally posted by Luke@tirerack
Kev ... they are available in many different offsets
Awiner .... they already do
Those offsets of et25 on the 18X8 and the 19X8.5 seem perfect for the W210 E55 up front using 245/40/18.
#53
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
I mis typed. I should have asked, is ASA planning to make a 19" rim in the ST4 style without the allen bolt hardware ?
#56
TR Moderator & Tire God
depends on the weather
Originally posted by AMG493
I'm interested in the ST4 wheels, but don't want to go up to 19 in., will the ST4 18 in. wheels fit on an 04 SL55? If not, why not? Thanks.
#57
Originally posted by TCM GLX
Luke, do the 19x9.5 have a bigger lip than the 19x8.5? This is for the ASA ST4 that I am asking.
#58
nope
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
#59
Suggested offset for '01 SLK320 Sport
Hey Luke,
For these wheels in an 18x8 and 18x9 staggered setup, what would be the suggested Offset and tire sizes for both the fronts and rears for an '01 SLK 320 Sport?
Also, do you know if the wheels require cone or ball type lug bolts? And would the stock lug bolts work? Or would these require new, perhaps shorter, lug bolts?
Thanks!
Thanks!
#60
'99 E430
what wheel size for '99 E430
Luke,
what offset and bolt pattern is needed for a '99 E430 using a set of 17 " wheels and also quote me for 18" wheels also on the silver ASA ST4 model wheels with the lip, thanks.
#61
99 E430
18X8 5-112 ET37
18X9 5-112 ET32
SLK320
18X8 5-112 ET37 ... 225/40-18
18X9 5-112 ET32 ... 255/35-18
I will include new lug hardware with all of the wheels as well as MB center caps at no charge
18X8 5-112 ET37
18X9 5-112 ET32
SLK320
#62
2013 GL550
Luke - On your site it looks like I can only get 18x8 and 18x9 in chrome on the ST4 style. But if I go 19" I can get silver finish. Is that true? No silver on the 18"?
#63
silver or chrome in both 18" and 19" ...... the silver ones are not in stock at this time that is why they do not show up at this time ... they are supposed to arrive 3-15
#64
2013 GL550
Thanks Luke! Do you have pricing on the 18x8 and 18x9 in the silver? I will likely do the staggered setup on the E500 for the summer. Any issues with that?
Bruce
Bruce
#66
pricing for the ST4
silver w/ machined lip
18X8 ASA ST4 $209.00
REAR ONLY
18X9 ASA ST4 $219.00
19X8.5 ASA ST4 $269.00
REAR ONLY
19X9.5 ASA ST4 $279.00
chrome
18X8 5ST4 $329.00
REAR ONLY
18X9 ASA ST4 $339.00
FRONT/REAR
19X8.5 ASA ST4 $389.00
REAR ONLY
19X9.5 ASA ST4 $399.00
REAR ONLY
REAR ONLY
chrome
18X8 5ST4 $329.00
REAR ONLY
FRONT/REAR
REAR ONLY
#67
2013 GL550
Luke - Thanks. I'll contact you after 3/15/04 for a quote. Maybe I'll cruise over and have you mount them. Get your hands dirty again! Hope all is well. If you go to LaSalle Grille again, hit my brother up for a drink!
Bruce
Bruce
#69
1 Post
2003 C230 K , 2001 ML320
I am diffenitely interested in the 18s for my W203 Coupe. Someone should kick start the web master at TireRack, look at http://www.tirerack.com/images/pdf/tires.pdf, they have the add from January and it is almost March.
#71
LUKE
Are you guys still on schedule to receive the silver wheels on 3/15? Any possibility of getting them earlier? On the other hand, any possibility of getting them later as well?
I have already ordered a set through Lee while you were out.
By the way, a belated Happy Birthday to Luke!
