help
Old Mar 19, 2015 | 12:46 PM
jonesyboy's Avatar
mercedes s320 cdi l
help
hi I've got a 2006 s class last week the air suspension bottomed out I've replaced the compressor and the relay but the pump will still not run have you guys any ideas thanks
Old Mar 20, 2015 | 09:32 AM
Garticus's Avatar
W221/S550
There might be a fuse somewhere........before the relay.
If you can easily pull the relay......start the car and put a multi meter on the posts for the relay and see if power is getting to the relay.
Old Mar 20, 2015 | 11:50 AM
jonesyboy's Avatar
mercedes s320 cdi l
Thanks graticus I've by passed the fuse and relay got pump running but still no air think it may be valve block
