Where to buy camber kit
Old Jan 25, 2004 | 06:36 PM
ggong5150's Avatar
03 C320 (For Sale), 08 Audi TT
I'm looking for a camber kit for a 2003 C320. I have 19x8.5 front and 19x9.5 rear wheels with 235/35/19 and 265/30/19 tires. Also I'm running H&R sport springs. I noticed the rear is worn out on the inside. Where can I buy a camber kit and are there different types of kits available?
Old Jan 26, 2004 | 12:08 AM
Petie's Avatar
2000 CLK430
Kmac makes adjustable camber kits....i remember they were $340 for the front and rear on my CLK
Harris at Harton Motorworks here on the forum has them slightly cheaper than this (i suggest this if you need a fair amount of camber adjustment)
if you just need slight adjustment, you can buy crash bolts from your mercedes dealer, i believe this only gives you about .75 degrees of adjustment though, so if you need more, this wouldnt work. however, this would be much cheaper. i believe these arent adjustable, just bolts that change a set amount. not sure, id say ask your dealer.
