SLR ceramic brake surface cracks and squeal
Old Jun 16, 2015 | 11:54 AM
Mercedesslrs's Avatar
Mercedes SLR, G63, s500 2013, Bentley GTC and 1970 Rolls Royce Corniche
Hey guys,
I'm reposting this here cause I'm not sure where to post it.
I have a 2006 SLR with about 2000 miles. During my service at a shop, not the delear, they informed me the ceramic brakes have surface cracks and this was causing the squeal. In past I did my homework and found ceramics squeal no mater what you do or replace. The squeal only appears now after driving and warming the brakes up. Cold they are quite. And they only squeak when I'm about to stop. IE, slow speed up to a traffic light. I was told before to stop the squeal I need to hard brake from crazy speed which I never did. My question is this do I need to replace the brakes? If I do which after market brake company should I use? I was quoted 370,000 AED in Dubai from Brembo and this is with a 40% discount which works out to 100,750 USD for 4 disc, pads and sensors. I found carbon ceramic brakes from wilwood for 5000 USD which is wayyyy better but have no clue about them at all. Any help would be appreciated. To sum up again, do I need new brakes or am I good as?
Old Jun 16, 2015 | 03:28 PM
giuseppesalvato's Avatar
E220cdi avantgarde
try using EBC red brake pads, these are available in the UK, not sure about your location, just found on line, should be easy to obtain, hair line cracks smell a bit fishy to me.
Old Jun 16, 2015 | 09:11 PM
I'll check them out. I can take a picture and post it to show the issue. They say it's causing the squeal but I read the cracks are normal so no idea
