shocks????
Old Feb 3, 2004 | 05:04 AM
mrchocolatte's Avatar
c 320
shocks????
I would like to know...
what is the symptoms that the shock in your car needs to be replaced?
can it be justified according to the ride?
I have a w203-19" lowered wheels.
Thanks a lot guys...
Old Feb 3, 2004 | 10:40 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
leaking fluid
or
bouciness .... continued bouncing after a bump
Old Feb 4, 2004 | 12:37 AM
Sincity's Avatar
Push down on your front fender. If the vehicle occilates more than 1 x, you may have worn shocks. Also bouncing around while driving is a good indicator as mentioned above by Luke.
Old Feb 4, 2004 | 04:41 AM
c 320
Thanks guys for the tips....
but, Sincity, I hardly can push down the front fender or I can only feel a small 'bounce' when i pushed it.
Thanks anyway.
Old Feb 4, 2004 | 07:12 PM
yugger's Avatar
1997 E420
My car was very "floaty" before replacing the shocks. Was scary at high speeds and going around corners, especially if they were bumpy.
I couldn't push the front end down before the replacement but could be because I don't weigh enough?
Much better roadfeel and ride now.
