rear end loose under hard braking
Old Oct 10, 2015 | 08:39 PM
gixxerboy's Avatar
2013 CLS63, 2001 ML430, 2012 e350 coupe
So i just upgraded my front brake set up, drilled slotted rotors, braided hoses and stop tech pads. My rear is still the stock set up.
Normal braking is fine, a couple times under hard braking the rear end got loose. Normally that means to much rear bias, but if anything the front should be allot stronger now after the upgrades. Never had this issue before doing the fronts.
I'm not sure what the issue can be, but has me worried about upgrading the rear set up soon
