EXPERT HELP NEEDED...Suspension Question...
Old Feb 15, 2004 | 05:14 PM
joesc230's Avatar
2002 C230 Kompressor
Hi everyone,
I recently had a very heavy audio system installed in the trunk of my 02 C230K Coupe...the result is that the rear of my car is dropped down significantly lower than the front end.
I was told that the best solution to my problem would be to buy Vogtland Audio Springs, which create a 30mm overall drop in the car (taking into account 100 lbs of extra rear weight), and to then get #4 Spring Pads as well (i guess to raise the rear up more)...
does this sound like the best way to go? are the #4 pads needed?
Please help me out here!!! Thanks!!!
BTW...if you need to see a pic of my car to get an idea...click the link below:
My Benz
Old Feb 16, 2004 | 12:40 AM
KWiK's Avatar
2002 C230 : 2007 C230
Yes, get the Vogtland audio springs & be sure to put #4 pads in the rear
