ABC oil leak
Old Nov 25, 2015 | 12:05 PM
retiredcaddyman's Avatar
2004 SL 500
ABC oil leak
I own a 2004 Mercedes SL500 , A beautiful Car, I might add. For the last several months when driving over a bump the ABC light would come on for a few seconds. (Heard that one before huh?) Then when driving the car the last time, we heard a noise like a radiator hose bursting. We were not far from home so we continued on and put her away in the garage. In the morning I found a small pool of oil under and behind left front tire. Up on the rack she went and I traced the oil leak to a blown O ring. After replacing the 0 ring and refilling the ABC fluid tank to half full, I would start the engine and it would burp oil out the reservoir every time I started it up. (What a Mess!) Do I need to bleed the system, and if I do can you tell me the procedure?
Thanks So Much In Advance!
