Brake Dust Shieds
![](https://mbworld.org/forums/images/ranks/veteran_air_force.png)
Not recommended! If possible clean you wheels more often or try aftermarket brake pads which are more dust free. These things limit the air flow and detract from brake cooling. They are also a pain to put on for a Mercedes using wheel bolts. It will take two people to put on a Mercedes wheel using covers because of the wheel bolts. It is impossible to hold the cover on and then put the wheel on.
