Hi,
Im new here.
Wanted to know if these rims with these spec: 5x20 ET45 front / 10,5x20 ET45 rear
would fit my w216 cl500 2006-7 without any problem?
What is the spec of the tire which should fit these rims -both front and rear?
Regards
Im new here.
Regards
Hi, and welcome!
Your wheels should work perfectly with the W216. The stock offset is et43. Your front wheels should work with a width of 245 or more commonly recommended 255. The rear width works with 275 to as much as 295. Some go even wider. Good luck.
Currently Active Users (1)
