Question regarding C32 AMG spacer..
Old Mar 19, 2004 | 11:31 PM
Instuh's Avatar
I have a problem fitting 18x8 AMG Dualspoke wheels originally bought for a 2003 CL500 NON SPORT onto a 2003 C32 AMG. They bolt up fine, but do not fit over the Brembo/AMG Caliper.... The rears (18x9) fit with a tiny bit of clearance.
I know I need a spacer to fit, I just need to decide what Spacer and what size. I assume I should go line the wheel up the the hub, then measure how much room it needs...and buy a spacer and corresponding bolts for that size?
Please give me a website with varying spacer sizes and bolts.
Thanks.
Old Mar 20, 2004 | 08:04 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
spacers = bad idea
Old Mar 20, 2004 | 01:12 PM
theine's Avatar
2014 GLK250 BlueTec & 2009 ML320 BlueTec
I put 3 mm spacers to clear my C32 AMG brakes with 7.5 x 17 AMG wheels, just temporary cause I ordered 18" ST4's.
If you wan't to stick with the spacers, get hub centered ones from H&R
Old Mar 21, 2004 | 02:01 PM
Instuh's Avatar
Originally posted by Luke@tirerack
spacers = bad idea
elaborate
Old Mar 24, 2004 | 03:57 AM
clkal's Avatar
01' CLK55
don't the CL rims have 14mm holes? Your C class should use 12mm. this will cause future problems.
