Can I use staggered wheels on a 4matic
Old Nov 1, 2016 | 01:58 PM
RebelliousJones's Avatar
s550
I Have A 2008 Mercedes S550 4Matic. I know you can put staggered wheels under 3%. But I'm really lost on how to do the math. I would love someone to help me with a simple yes or no because too many answers tend to confuse me.
I was interested in buying a used pair of 22in Stock wheels. The Front tires are 235/30/22 & The Rear Tires 295/25/22. All same brand and thread. Can I put these wheels on my car being 4matic without any malfunction or problems?
Thanks in advanced
Old Mar 15, 2017 | 09:52 PM
Dale B's Avatar
1999 SL500, 2001 S430, 1998 Boxster, 1978 930
Check with the tire manufacturer that you plan to use. They can give you the tire diameter and circumference. Those are the measurements that you need to compare front verses rear.
Old Mar 21, 2017 | 06:16 PM
rpr2's Avatar
S 560C217; S550 W222
Thanks in advanced
Use this calculator: http://www.1010tires.com/Tools/Tire-Size-Calculator
It does the math for you!
I have a CL550 4Matic and run 245/35/21 front; 285/30/21 rear. The difference in overall diameter is negligible per the calculator. Running staggered set up within 3% difference in diameter should pose no issues whatsoever.
Old May 18, 2017 | 07:20 AM
raja777m's Avatar
2014 E350 4M Diamond Silver
my 2014 e350 4m Lux needs new AMG 18s, and I used the above tool.
It gave me two options on my model, as submodels:
245/45/R17 8.5X17 and 8X17
http://www.1010tires.com/Tools/Tire-...5R18/265-35R18
Both gave me 0.14%(too slow) front and 1.49%(too fast) rear.
Is that still fine to go with it?
Thanks.
Old May 18, 2017 | 09:28 PM
raja777m's Avatar
bump.
