question for luke or harris
not correctly .... w211 uses a much lower offset so, the wheel would not only stick out too far but, it wouldn't have the right load capacity
thank you,
how about with the proper spacers and bolts from Brabus?? tia
Will Brabus wheels that where on my W211 fit an '02 s500 sport?? tia
But if the wheels are 18's, then probably not.
Actually, depending on which size. All Brabus 19's have ET45 offset, so if you want to fit those wheels on a W211, all you have to do is to take out the hub-centric spacers and it will be a direct bolt on.
just so I know, what are the front and rear offsets of the W211s, I believe the rear spacers are slightly wider than fronts?? thanks.
ok makes sense, thanks!
Brabus uses ET29 front and ET35 rear. Since you are too lazy, you have to do the math yourself!!
