Rotating staggared tires
Old Mar 28, 2004 | 02:18 PM
clco's Avatar
'99 E430
With one set of tires on the front, 18x8, and another set on the back, 18x9, do you just switch them side to side every 6 months? Or is there no need to even do that, and just let them wear out?
I want to maximize the life out of the tire.
Old Mar 28, 2004 | 02:47 PM
E55AMG99's Avatar
1951 Caterpiller D6
Nothing you can do to maximize life except keep them properly inflated. Unless you have a serious alignment problem, your tires will be wearing the same on both sides of the car. People disagree about dismounting the tires and swapping them so the outside of the left tire is now the inside of the right side. Many tires used to wear faster when treated this way. Also, some tires are directional in that the outside of the tire must always be on the outside no matter where it is mounted.
Confused? Me too!
