Tire rotation for staggered set up
Old Mar 30, 2004 | 01:45 AM
jjrho's Avatar
2001 s500
hi,
on s500Sport with staggered set up,
do you guys recommend rotation across axle?
otherwise, with unidirection tires, shouldn't you be able to for even wear, as long as they are not Right or left specific?
otherwise, these tires stay in the same wheel/corner for the entire duration.... and if you don't have perfect alignment..... eneven/premature tire wear/ware....?
help...
j.rho
Old Mar 30, 2004 | 11:01 AM
raerae28's Avatar
With a staggered setup you really cant do much rotation.
If you get uni-directional and staggered then you DEFINITELY can't rotate.
With just uni-directional you could bump the backs to the front and the fronts to the back but thats it.
Its an expensive sporty look for anything over 18" staggered wheels.
R.W.
Old Mar 31, 2004 | 01:12 AM
jjrho's Avatar
2001 s500
staggered rotation
ok... well,how about rotation on the same axle...that is, keep it spinning same direction but switch between right and left wheel ?
j.rho
Old Mar 31, 2004 | 09:12 AM
internet_mafia's Avatar
Even if you rotate across the axis (left-right), you wouldn't be saving that much tread. The rear tires will wear across the entire tire, so no point in rotating those. The fronts wear on the inside as well due to steering, so its not like you have "brand new" tread waiting to be used...
Old Apr 27, 2004 | 03:30 PM
DMI+RY's Avatar
W220
Re: staggered rotation
j.rho
In that case you have to make sure it's not directional tires...
Old Apr 28, 2004 | 11:44 AM
ima55r2's Avatar
2018 Mclaren 720s, 2021 Aston Martin DBX
j.rho
In this case, the tread shouldn't be assymetrical.
Old Apr 28, 2004 | 12:53 PM
AMG BRED's Avatar
CLK63 Black Series
not according to this guy
Got Camber?
:p
i was looking for more pics of slammed MBs.. but that's the best i could find.
