W205 Wheel Fitment Advice
1. Will these fit?
2. Will they be flush or stick out?
3. What tire size would I need to accommodate more wheel in the rear and front? I don't want them to be too stretched.
Thanks in advance. I sadly don't know much about how the offset/wheel specs change things.
Christian
Edit:
If I'm considering 18" that are 45mm offset.. does that change anything instead of the 19?
1. Will these fit?
Christian
Edit:
1.) Yes they will fit. Easily in the rear, barely clears the control arm up front.
2.) fronts will be flush. Rears will be flush with the top of the fender but looking at the car from the rear you'll see approx 1.5-2 inches of tire sticking out where the rear quarter panel meets the bumper. It makes the c300 have an aggressive and powerfulooking "stance".
would 19in rims 8.5/9.5 offset 35/38 fit on a 16 C300 base model
and how do U think it would look on a C300 as it it rubbing ?
Thanks in advance for your time
