AMG S63 Wheel Offset
2008 S63 AMG
I have a 2008 Mercedes S63 with OEM 20" wheels (wider tires/wheels in rear than front). I'm considering replacement wheels. What is the factory offset in mm for these two size wheels? Thanks! - Russ
The absolute best way to get the correct answer is to dismount one front and one rear (the offsets are different) and look on the rim. OEM rims have the offsets stamped on the rims.
Go with a 35mm offset. That will push the wheels flush with wheel well. The factory wheels are sucked in and this makes a huge difference appearance wise. I just did it.
